C
		CrissCross
First off, I am new to the site and very impressed with the members and knowledge base!
Finally took my 80 vette out of the garage after a 3 year period, and found the rad is gone. In replacing the rad, I am now going to install all the missing rad seals and rad support to hood seals. I am doing this since I have been having troubles with overheating in the past.
Previous owner removed the stock Air Cleaner and the duct which sits over the rad and the other duct which runs on the right side.
Luckily he kept them and gave it to me when I purchased the vehicle.
I would like to install the stock setup but am having trouble determining how the duct sitting on top of the rad support is to be mounted?? Can someone give me some guidance?? Some close up pictures would be great!! Also what hardware (screws/bolts) is required...
I see the three mounting holes in the duct (2 on left, 1 on right) but they just don't seem to line up to anything. The other confusing item is if the seals pointing towards the engine are to be under the duct or over it?? Since the seals where missing to begin, with its hard to see.
Thanks!
CC
Thanks!
CC
		 ), but someone will be able to answer your question by morning I'll bet.
