V
Vette66AirCoupe
Regarding my '66 coupe, I just put new guts in my steering column as part of the instrument cluster rebuild project. I replaced both the switch & harness and the cam during the process. 've got a squeak in there when I turn the wheel that sound like plastic. What kind of lube should I use and where does it go? Also, the right turn signal doesn't cancel itself but the left one does. Any advice on how I can rectify that situation? Other than those two annoyances everything went fine. Got the oil changed, replaed the leaky master cylinder, changed the anti freeze and replaced the thermostat. I'm rarin' to go but not with that high pitched squeek! I replaced both the switch & harness and the cam during the process/
