T
		tom_85_vet
I just did some work on my 85.  Replaced the FIs and the distributor.  Now I can not get it to start.  My first mistake was to change both parts at the same time.  I have now put the old distributor back on, but could have it 180 degrees out (tryed both ways).  My thought now is that fuel has not made it into the injectors, since I had to purge the fuel system.  The battery is now running low, so I will have to jump it for the next round of touble shooting.  Also, I did check the fuel pressue with a guage and it goes up to 34psi when I turn the car over, but then quite quickly down to zero.  Should the fuel pressue remain in the system for some time?  Is this an indication that fuel has not made it to the injectors, or is there a leak in the system?  I did check all connection, and not gas is leaking.
Thanks for any help.
