Subfixer
Rowdy1 said:Well after much talking to many people, a very simple thing was asked of me today. Did I look to see if the driveshaft was turning when I let the clutch out, even though there is NO noise and the 62 doesn't move. I didn't blow the new Richmond Gear Super T10 trans or the new Centerforce clutch, I snapped the pinion shaft in the rear as near as I can tell without removing the pumpkin because the driveshaft IS turning.
The same thing happend to my 62 many years ago. When disassembled, the problem was the ring gear bolts had all sheared off. I was running 4.88's with a ring gear spacer. Guess that setup wasn't strong enough. Reloaded with a set of 4.56's without a spacer and no problems until I lost the car to fire.
