Man this will be tough on line!!:W:W:W
I'd remove the engine covers and inspect every vacuum line you see!
I'd double check that short hose at the PCV Valve,Remove and look at it good!!
 I've had to replace 2 on my 03 in 65,000 miles!
Just did it a couple months ago!!
Has it ever had the Spark Plugs changed?Has it ever had the SP Wires changed? Have you ever ran any Techron threw it??(If not maybe you should!
 How bout the fuel filter??
I'll post this,but it probly won't do any good unless you have a scanner and some other things!! But it may give you some sort of idea!
If you don't find any vacuum leaks,you should probly take it to somebody to check it out!!
 DTC P0300
System Description
DTC P0300
System Description
The powertrain control module (PCM) uses information from the crankshaft position (CKP) sensors and from the camshaft position (CMP) sensor in order to determine if engine misfire is occurring. By monitoring the variations in the crankshaft rotational speed for each cylinder, the PCM is able to detect individual cylinder misfire events. A misfire rate that is high enough can cause damage to the three-way catalytic converter (TWC). The malfunction indicator lamp (MIL) will flash if converter damage conditions are present.
Conditions for Running the DTC
- DTCs P0101, P0102, P0103, P0117, P0118, P0125, P0335, P0336, P0341, P0342, P0343, P0500, P0502, P0503, P1120, P1220, P1221, or P1258 are not set.
- The engine speed is between 425-3000 RPM.
- The ignition voltage is between 10-18 volts.
- The engine coolant temperature (ECT) is between -7°C-130°C (+19°F-266°F).
- The fuel level is more than 10 percent.
- The throttle angle is steady within 1 percent.
- The anti-lock break system (ABS) and the traction control are not active.
- The transmission is not changing gears.
- The secondary air injection (AIR) diagnostic test is not in progress.
- The A/C clutch is in a steady state.
- The engine is not in fuel shut-off or in decel fuel cut-off.
- The antilock brake system (ABS) signals are not exceeding the rough road thresholds.
Conditions for Setting the DTC
- The PCM determines that an emission type misfire is present.
- The PCM determines that a catalyst-damaging misfire is present.
Action Taken When the DTC Sets
- The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
- The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
- The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
- A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
- A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
- Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
- Before you service the PCM and the throttle actuator control (TAC), remove any debris from the module connector surfaces. Inspect the module connector gaskets when you diagnose or replace the modules. Ensure that the gaskets are correctly installed. The gaskets prevent contaminate intrusion into the modules.
- For any test that requires probing the PCM or probing a component harness connector, use the J 35616-A connector test adapter kit . Using this kit prevents damage to the harness and component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
- Running the vehicle out of fuel causes sufficient misfire to set DTC P0300. A vehicle that is out of fuel may have DTC P0461 and DTC P1431 also set.
- A restricted fuel filter can cause sufficient misfire to set DTC P0300. Refer to Fuel System Diagnosis .
- A misfire that only occurs during certain conditions may be difficult to locate. Observe the Freeze Frame and the Failure Records in order to determine when the DTC set.
- Excessive vibration from sources other than the engine could cause a misfire DTC. Possible sources of vibration are listed below:
- Variable thickness in the brake rotor
- An unbalanced propeller shaft
- Certain rough road conditions
- If more than 1 cylinder is misfiring, the scan tool may only display 1 misfiring cylinder. This condition is not apparent until the repair is completed. Also, if an ignition coil or module ground circuit is open for 1 side of the engine, the scan tool may only display 2 or 3 misfiring cylinders. Inspect the ground circuit for the ignition coil and for the modules on the cylinder bank of the engine that has more than one misfiring cylinder.
- A misfire may not be apparent at idle. The misfire may only occur above idle during a load. Road-test the vehicle, and monitor the misfire current counters.
- For an intermittent condition, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
- The Misfire Current Counters will not increment if certain DTCs set at the same time or after DTC P0300 sets.
 If more than 1 cylinder is misfiring, the Misfire Current Counters may increment for only one cylinder. For example, Cylinders 1 and Cylinder 8 are both misfiring, but only Cylinder 8 increments on the Misfire Current Counter.
 If one of the injector fuses is open, only 2 or 3 Misfire Current Counters may increment for the corresponding side of the engine.
 Wetting down the secondary ignition system with water from a spray bottle may help to locate damaged or deteriorated components. When you apply the water, look and listen for arcing or for misfiring.
 If the Misfire Current Counters are incrementing and there is no apparent misfire, an erratic crankshaft position (CKP) sensor signal could be the cause. Perform the diagnostic that are listed on the table for DTC P0335 first if you suspect this condition.
 If a misfire is present and you suspect a fuel control concern, force the fuel system into Open Loop using the scan tool, and allow the engine to run for a few minutes. If this procedure eliminates the misfire, refer to any fuel control-related DTCs which are set. If no other DTCs are set, refer to the Engine Scan Tool Data List.
 The cylinder with the more significant misfire may cause another cylinder's counter to increment by a small amount.
 If the engine misfire moves with the spark plug, this is good indication that you should replace the spark plug.
 An engine mechanical condition can cause a spark plug to gas foul. Inspect for loose rockers, for collapsed lifters, or for worn camshaft lobes.
- If the MIL is flashing, this indicates that a Catalyst Misfire has occurred. Drive the vehicle in the conditions to run the catalyst diagnostic.
DTC P0300 - Engine Misfire Detected
Step
Action
Values
Yes
No
1
Did you perform Diagnostic System Check-Engine Controls?
Go to
Step 2
Go to
Diagnostic System Check - Engine Controls
2
Important
If any DTCs other than P0135 and P0155 are set, refer to those DTCs before proceeding with this diagnostic.
- Install the scan tool. Start the engine.
- Use a scan tool in order to monitor all the Misfire Current Counters on the Misfire Data List. There are a total of 8 counters, with 1 counter per cylinder.
Are any of the Misfire Current Counters incrementing?
Go to
Step 4
Go to
Step 3
3
- Turn ON the ignition, leaving the engine OFF. Review the Freeze Frame and the Failure Records data for this DTC, and observe the parameters. Turn OFF the ignition for 15 seconds. Start the engine. Operate the vehicle within the conditions required for this diagnostic to run, and as close as possible to the conditions that the Freeze Frame and Failure Records recorded. Special operating conditions that you need to meet before the PCM will run this diagnostic, where applicable, are listed in Conditions for Running the DTC.
- Select the DTC option and the Specific DTC option, and then enter the DTC number using the scan tool.
Does the scan tool indicate that this diagnostic failed this ignition?
Go to
Step 4
Go to Diagnostic Aids
4
Is only one Misfire counter incrementing?
Go to
Step 6
Go to
Step 5
5
Inspect for the following conditions:
- Inspect the accessory drive belt and the pulleys for damage or for misalignment. Refer to Drive Belt Vibration Diagnosis in Engine Mechanical.
- Inspect the vacuum hoses for splits, for kinks, and for proper connections.
- Inspect the throttle body and the intake manifold for vacuum leaks.
- Inspect the crankcase ventilation valve and system for vacuum leaks.
- Inspect the PCM grounds for being clean and secure. Refer to Testing for Intermittent and Poor Connections in Wiring Systems .
- Verify that all injector harness connectors are connected to the proper injector or cylinder.
- Inspect the injector and the ignition control fuses for an open. If you find an open fuse, locate and repair the shorted circuit. Refer to Wiring Repairs in Wiring Systems.
- Test for low fuel pressure or for restricted fuel flow. Refer to Fuel System Diagnosis .
- Inspect for a restricted exhaust. Refer to Restricted Exhaust in Engine Exhaust.
- Inspect the fuel for poor fuel quality. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
Did any of the above inspections isolate a condition requiring a repair?
Go to
Step 17
Go to
Step 6
6
- Turn OFF the ignition.Disconnect the injector that corresponds to the Misfire Current Counters that was incrementing. Connect the injector test lamp J 34730-2C to the injector electrical connector.
- Start the engine.
Is the injector test lamp flashing?
Go to
Step 7
Go to
DTC P0200
7
- Turn OFF the ignition. Reconnect the injector harness electrical connector. Disconnect the ignition wires from the spark plug that corresponds to the Misfire Current Counters that was incrementing. Install spark tester J 26792 to a ground.
- Start the engine.
Does the spark jump the tester gap, and is the spark consistent?
Go to
Step 9
Go to Step 8
8
- Remove the ignition wire for the cylinder that is misfiring.
- Use a DMM in order to measure the resistance of the ignition wire.
Is the ignition wire resistance less than the specified resistance?
700 ohms
Go to
Electronic Ignition (EI) System Diagnosis
Go to
Step 16
9
- Remove the spark plugs from the cylinder that indicated a misfire.
- Inspect the spark plugs. Refer to Spark Plug Replacement .
Does the spark plug appear OK?
Go to
Step 10
Go to
Step 11
10
Important
If the Injector Coil Test Procedure does not isolate the condition, refer to Base Engine Misfire without Internal Engine Noises in Engine Mechanical.
- Swap the suspected spark plug with another cylinder that is operating properly.
- Operate the vehicle under the same conditions in which the misfire occurred.
Did the misfire move with the spark plug?
Go to
Step 15
Go to
Fuel Injector Coil Test
11
Are the spark plugs oil or coolant fouled?
Go to
Go to
Step 12
12
Important
If the Fuel System Diagnosis does not isolate the condition, refer to Base Engine Misfire without Internal Engine Noises in Engine Mechanical.
Are the spark plugs gas fouled?
Go to
Go to
Step 13
13
Important
Do the spark plugs show any signs of being cracked, worn, or improperly gapped?
Go to
Step 14
Go to
14
Replace or re-gap spark plugs. If you find an improper gap, use a wire-type gauge in order to re-gap spark plugs. Refer to
Did you complete the replacement?
Go to
Step 17
15
Replace the faulty spark plugs. Refer to
Go to
Step 17
16
Replace the faulty ignition wires. Refer to
Spark Plug Wire Replacement .
Go to
Step 17
17
Was the MIL flashing?
Go to
DTC P0420 or P0430
Go to
Step 18
18
- Use a scan tool in order to clear the DTCs. Turn OFF the ignition for 30 seconds. Start the engine.
- Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to
Step 19
Go to
Step 2
19
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to
Diagnostic Trouble Code (DTC) List
System OK
