- Thread starter
- #21
- Joined
- Aug 29, 2001
- Messages
- 3,239
- Location
- Norcross, Georgia, United Stat
- Corvette
- 2017 Arctic White Grand Sport
Pete,
Advance curve does come in a little later than some but I was concerned at the lower curve point indicated with the next lighter set of springs. I think they brought it in at 2800 and I had gotten some feedback about pre-ignition. Once I get this problem licked, I may advance it a little more aggreesively.
I'll check this weekend at NAPA and see if I can get a fuel pressure gauge.
Lars has a pretty good reputation in this area. I might be a little high but are you sure about 38 degrees combined?Distributor Vacuum Advance Control Units Specs and facts for GM Distributors by Lars Grimsrud.
Most GM V8 engines (not including "fast-burn" style heads), and specifically Chevys, will produce peak torque and power at wide open throttle with a total timing advance of 36 degrees (some will take 38). Also, a GM V8 engine, under light load and steady-state cruise, will accept a maximum timing advance of about 52 degrees. Some will take up to 54 degrees advance under these conditions. Once you advance the timing beyond this, the engine/car will start to "chug" or "jerk" at cruise due to the over-advanced timing condition. Anything less than 52 degrees produces less than optimum fuel economy at cruise speed.
