C
C3RVETTE
http://www.carhoods.com/HoodPages/PF-470.htm
(High-Tech design inner liner fully supports the outer skin, providing a show worthy inner structure which is smooth, rigid, and ready for prep & paint. The Cormat reinforced surface is both strong and straight. Steel anchors allow for use with both OEM hinge & latch. Side 90° edges are left long, scoops & baffles come closed & require opening to make the hood functional. Lighter tension springs may be required. Part # TCVH-68 Weight approx + - 43 lbs)
--- http://www.usbody.com/Pages_Cars/68-Corvette.htm <--These 1st two ads look identical,whats that about? --- http://www.vfnfiberglass.com/6881vette.htm (73-82 - 4inch Cowl Induction Bolt On Hood Fits 68-72 .Price=450.00 Weight=20 Ship: Truck Freight)
---Since the 2nd one looks identical to the 1st,and the last 2 are essentially the same price...I'm picking the usbody hood for now.Any help? Or do you not like the style? I figure its pretty much the same as stock design,only with much more room for a taller manifold & air cleaner lid that breathes much better,& a cowl style hood that actually functions-unlike the stock one.
