Whiplash
It's been 8 months of slow but sure progress. My 71 one owners now has:
1) New Radiator
2) New Water Pump
3) New Front Suspension
4) New Front Steering
5) New Rear Spring
6) New Shocks All Around
7) Reupholstered Seats
8) New Soft Top (I cheated and had a local shop install it. Chickened out on doing it myself. Great job by the shop however, even if it was a bit pricy.)
9) New Tires
And now Great Oil Pressure!
Since I got it running again a few weeks ago, after fixing oil, steering, and cooling leaks, I noticed my oil pressure was very scary. I went through a lot of trouble shooting for guages, oil level, etc and was able to get 20 lbs at idle and 35 lbs at cruise with oil pressure rising to 40 lbs when revving the engine.
Last week when I went to get the soft top on I noticed that the oil pressure dropped to ZERO when accelerating. Ugggg. It would come back up when cruising but would drop when braking, accelerating, or idling when hot.
There are a lot of things that can cause this from bad oil pump, bad high pressure valve spring, bad bypass valve in oil filter housing, bad positinging of oil pick up.
I don't know what was actually wrong but I replaced the oil pump with a stock (regular volume) pump, new pickup screen, and new shaft with metal sleeve instead of the normal nylon. Replaced filter and filled her up with Castrol High Mileage 10w40 and WOW.
Now I have 40 lbs at idle and 70 at WOT. No problems at all.
A little hint. I think my problem was a combination of old oil pump and poorly positioned pick up screen.
When installing a new oil pump and screen this trick worked great. DO USE the Fel-Pro one piece oil pan gasket. It's the bet $24 you can spend. Really cuts down pain when doing this with the engine installed in the car. To position the screen press it on the pump (I didn't have the special tool for this if you can get it you really want it), install the pump on the motor, tape 3 quarters to the bottom of the screen and gently place the pan on the engine WITHOUT the gasket. The idea here is to have the pan actuall push against the quarters and raise the pick up flush with the bottom of the pan while the quarters are touching. This will give you some gap between the bottom of the pickup and the bottom of the pan. Remove the pan very carefully so you don't bump the screen! Use a Sharpy pen and mark two point on the pickup tube and pump to mark position. Remove the pump and screen as an assembly and tack weld the pickup to the pump at two points being careful not to warp the tube. Reinstall pump, gasket, and pan, prime the pump, start her up and go.
The key to this trick is that the combined thickness of the gasket and 3 quarters will give you about a .365 in gap between the pickup and the bottom of the pan. The tack welds will keep the pickup from moving when you install the pan or while driving. You can certainly use the modeling clay process but I think this cut down on steps. Like I said my problem was probably a combination of a pickup that I bumped when installing the new gasket over the winter and a tired oil pump. I should have done this step the first time and I knew it then and was mad at myself for not doing it.
The good news is that the oil pressure is now great and the motor didn't get too much use with low oil pressure.
I want to thank everyone for the combination of tips on this forum that helped me figure this out. I just wanted to post my experience in one place in case anyone else is having this problem.
Have a great weekend.
Whiplash.
1) New Radiator
2) New Water Pump
5) New Rear Spring
9) New Tires
Whiplash.
