U
unleadedbrew
Is there any way to disconnect the stock security system from the horn and still have a horn? Pulling the security fuse (behind the information panel) disables the horn, also. ;help
I'm preparing to take the VATS module outta my 86 and It is my understanding that it is in somewhere above and behind the radio....idk, I hope that helps youdrkjr said:can you explain "front of the ECM under the pass side hush pad." please? My car is having a security problem, it will not start aftre driving for any length of time, i have to disconnect the battery for min. half hour and then it will start again, ONCE... I am DESPARATE to disconnect this damn security system!
Thanks!
