Vref
How do I make these valve cover, intake manifold and exhaust manifold
look like this
look like this
![graphite203.jpg](http://66.96.168.202/vette/web/graphite203.jpg)
Got it Thanks for the quick reply.paul79 said:That's my 1967. You posed the same question in "the other place" where I answered in detail. In brief the valve covers are powder-coated.
Here is another option: Aluma Blast for intake manifold and valve covers and Cast Iron hi temperature paint for the exhaust manifold. Check out this link.Vref said:How do I make these valve cover, intake manifold and exhaust manifold
look like this
Randy, according to the Edelbrock instructions I have for the 1406 carb, the Timed Vacuum Port on the passenger side of the carb is for emission controlled engines. The driver's side port as Paul has it, is for non-emission controlled engines.vette-dude said:Paul79,
I noticed in the pic that the vacuum line for the vacuum advance is coming out of the carb on the unported (full) vacuum side ( I think). Isn't the vacuum line suppose to be on the ported vacumm side? I not sure but I just changed this around on a buddy's car and it runs alot better and gets better mileage. Maybe yours is right and I'm wrong but now I am curious. Anybody know for sure?
Randy
"Ported" vacuum was one of the early, crude emission strategies used to optimize the operation of the A.I.R. system in the days prior to catalytic converter technology, and nothing more; retarding the timing at idle increased exhaust gas temperature to ensure a good "afterburn" of hydrocarbons when the exhaust gases met the injected fresh air in the manifolds, and it reduced peak combustion temperature for reduced NOX generation. It also de-stabilized idle, reduced power due to retarded initial timing and a slow centrfugal advance curve, increased coolant temperatures due to heat transfer through the (hotter) exhaust port walls, reduced fuel economy, and degraded off-idle throttle response. Simply a band-aid in the pre-converter days, and has no place on a performance engine.vette-dude said:Okay, but if the drivers side port is full vacuum (non-timed) wouldn't that pull the vacuum advance on all the time in the distributor? therefore advancing the timing at idle? Maybe the vacuum cannister has an adjustable spring in it and it is set up to overcome the lower vacuum at idle thus keeping the dist from being advanced. Oh well, just wondering--Sorry for the hijack.
Randy
Thanks for the explanation.JohnZ said:"Ported" vacuum was one of the early, crude emission strategies used to optimize the operation of the A.I.R. system in the days prior to catalytic converter technology, and nothing more; retarding the timing at idle increased exhaust gas temperature to ensure a good "afterburn" of hydrocarbons when the exhaust gases met the injected fresh air in the manifolds, and it reduced peak combustion temperature for reduced NOX generation. It also de-stabilized idle, reduced power due to retarded initial timing and a slow centrfugal advance curve, increased coolant temperatures due to heat transfer through the (hotter) exhaust port walls, reduced fuel economy, and degraded off-idle throttle response. Simply a band-aid in the pre-converter days, and has no place on a performance engine.
