trackitman
Tom/Dave - Thanks, I now see your point. It is a sealed unit. The instructions with the assembly kind of threw me off a little. Want to make sure I'm doing it right.
Richr - I removed the tie rod in order to get more room to use a socket/wrench. If you can get the torx bolts off without removing it, you're cool. The GM manual recommends it.
Just a fyi - I decided to remove the knuckle and do the u-joints, seemed like the right thing to do since I was half way there.
Thanks you guys. Just bought this '92 convertible a couple of weeks ago, and, wouldn't you know it, the right rear wheel hub/bearing assembly failed on the drive home. The wheel was a' wobblin' going down the freeway, not a pretty sight! Anyway, after a 60 mile tow, it's in my garage. This is my first vette and I'm looking forward to the enjoyment of working on it and getting it back in shape!
Blaise "Trackitman"
Blaise "Trackitman"
