JAKE
Also, from personal experience, many years ago I shimmed the oil pump bypass spring with washers to increase the oil pressure. All was fine at first, during the summer months, but when the Chicago temps dropped and I started the engine it blew out the oil filter gasket immediately.
Apparently the by-passs couldn't by-pass all the oil it needed to. I dropped the pan, pulled the pump and removed the washers and all was well again - Well except for the BIG OIL SPILL CLEAN-UP I was faced with.
On my 86 Vette I once found the oil cooler adapter screws loose, but that only caused a small leak.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
