Ok, it's time for me to get my head squared onto the idle on my car.. :ugh
Symptoms:
Cold start, choke is on, runs at 1000rpm, like someone nailed it to the number..
When the choke goes out, it drops down to around 350-400, almost killing the engine, if i am not watching it (taking it out of gear, or giving it a little gas), it kills the engine. Even driving it, it drops like a rock, but as i am under acc. it comes right back..
After that, it idles at around 750-800, hopping around a bit on the tach, where before the move, it was idling at 550 like a rock..
Also, when it does idle, the car shakes left to right. Looks impressive but gets a little tiring for the fillings after a while.. :eyerole
Now, me not being overly technical, i havent checked on anything yet, warmer weather just started, so i might get a chance now.. Looking for some pointers. Last time i had a side to side shaker, one of the plugs had fouled, repeatedly on Number4, but thats been fixed (by throwing big stuff at it, like cables, dist etc) for years..
The ECM/CCC doesnt throw any codes, all seems to behaving normally and i fixed a small vaccuum (sp?) leak on the AC selector (the knob broke off on the selector, inside, so the selector came off, thus hissing, Glued the knob back into place, no more snakes in the Air.
So: Any easy to look for items? Other then the procedure for the qjet setup, any easy tweaks to get the idle back to normal ?
Any and all help welcome.. ;help
Tia!
-Stefan
Symptoms:
Tia!
-Stefan
