Assuming manual transmission - after installing the Hooker sidemounts, I find that the pivot ball on the Scoggins-Dickey bracket will not work in the bottom hole. :eyerole It hits the #5 exhaust pipe.
After moving the pivot ball to the upper hole, I find that I cannot install the cross-shaft as the pivot ball nut hits the 502 block and I don't have enough room between the ball and the frame bracket.
What was your solution? Start modifying the cross-shaft?
