6
69vettester
Hi all on the CACC.
Ive been away for months, glad to be back and see the C3 forum has grown and is thriving.
Ill be installing a new clutch assembly this week. During my research phase I came across an interesting difference of opinion regarding the pilot bushing or bearing.
Initially, the words of wisdom were " by all means go to the dealer and get the GM upgrade roller bearing(about $12) and use it in place of the Oil impregnated Bushing that comes with the GM clutch kits!
The reason being the bushing wears out, and the bearing doesnt.
Then, a week ago I happened across an long time GM service manager that said "not so". because in some cases the bearing can lose its grease packing(slung out or got too hot from the motor) then the bearing dries out and becomes toast!! He said he saw this happen many times, and mentioned that if the clutch assembly is in alignment, and stays that way like its supposed to, the grease impregnated bushing will never wear out.
This makes sense to me.
But Id like to hear Any comments about this issue from you guys??
Whatcha think??
I'll be starting the replacement tues.
Whatcha think??
