Instructions For Replacing 1987 Water Pump
EOLIVER
SAN DIEGO, CA
1989 DARK BLU METALIC SIX SPEED CONV
Tonight I discovered that my water pump and/or lower radiator hose was leaking heavily. In loooking through my CHILTONS manual (I plan on replacing it with an actual service manual) it directs me to evacuate the refrigerant and releif the pressure on the fuel system. Do I really have to do both of these to do this to change the water pump?
It's been awhile since mine's had air, and I can see where the fuel lines leading to the rails might have to be disconnected, but you should be able to maneuver the a/c out of the way in order to remove the water pump. Then again, I may be wrong. ;shrug
As usual, Ken has it exactly right :beer You can actually pull the motor without evacuating the AC :D
:duh I forgot that I did just that when I pulled mine -- twice! :L
Replaced mine a couple years back and didn't have to do either. You can unbolt and move what needs to be moved far enough out of the without disconnecting A/C, fuel or any other lines.
Unbolt it and tie it back with some tie-wire...you can tie it to the suspention. Just put a rag on the rubber piece ontop of the wheel well.
Last winter I did my 86 water pump and radiator...absolutely no need to evacuate the AC...dumb
It is a lot of work, as you do have to pull the power steering pump, alternator, AC compressor, etc., etc....I opted to change the timing chain (only a few more bolts, and the oil pan comes off easy to replace the timing chain cover, so I replaced the oil pump and starter....might as well!!!
Not a bad or hard job, just lots to do and very time consuming...but then, it IS a Vette
Just like Chiltons to make extra work for you. I believe that the December issue of Vette has a step by step article on the water pump change. I read it because it had pictures, unlike Playboy which I just read for the articles, of course.
Sorry, Hib.........my wife bought the subscription to Vette for me.:L
You do not have to evacuate the refrigerant to change the water pump, I don't know where you're reading that from. I changed my water pump a couple of months ago and it was pretty involved, because it was the first time I did it. I would plan on about 6 hours at a leisurely pace, just take your time. Everything has to come off the front of the engine. Yes you do have to disconnect the fuel lines in order to remove the a/c bracket, you should use flare nut wrenches on those fittings to prevent kinking the lines, it would be an enormous PITA if those lines kinked. It's easy to relieve fuel pressure, just remove the fuse that says FR or FP and start the car and run until it stops. Gas will still spill out, so keep some shop rags handy. I used Permatex thread sealant on the bolts that go into the water jacket, and they are dry as a bone. I used rtv on the gaskets, both sides, and it's a perfect seal and should be for years to come, knock on wood (knocking on my head). Might be a good idea to replace upper and lower radiator hoses as well as your heater hoses too.
What Mods Could Be Done While Changing Water Pump
what other items should I look to replace while changing out the water pump in my 1987 coupe
Concurring with the above, be gentle with the A/C as you move it aside. Too much strain on those hoses and connections can cause leaks, slow or not.
Change ALL hoses, especially the little one from the water pump to the intake, and both radiator hoses. Be gentle, also, on the radiator 'necks' for the same (leaks) reason. Possibles, on the heater hoses and serpentine belt. The belt can be inspected by turning inside/out and bending it backwards, looking for cracking. Cracks indicate replacement; lack of them is no guarantee it's okay.
A timing chain change would be a function of mileage, as it adds a couple of elements, like valve timing (simple, yet critical and proper alignment of the gears) and potential oil leaks.
If you're as far as the water pump, do consider replacing or at least looking at the timing chain. If it's the original chain, you can bet money it needs replacing. Worth looking into seeing as you've dug down to the water pump.
Ron ... :beer
Thanks Everybody
I'd like to thank eveyone for their advice. I finished the water pump replacement, radiator and throttle body cleaning yesterday. She's never run better or cooler.
Next stop replacement of the rear spring bushings/bolts. shocks (purchased new KYB's from summit racing) and an alignment.
Thanks again for al the great advice.
