poorboys831
The background lights do not come on in any position-tried to find a fuse that is for that area-does anyone know where it is ? Thanks Dennis L.:ugh
what year car ,instrament cluster fuse would be a quick place to check ,google it ? the light switch might be bad ,i have had that happen b4 not in a vette byt my truck 2 diff trucks actually!,fixed it both times the headlights would work but no dashThe background lights do not come on in any position-tried to find a fuse that is for that area-does anyone know where it is ? Thanks Dennis L.:ugh
This was sent to me and it worked;The background lights do not come on in any position-tried to find a fuse that is for that area-does anyone know where it is ? Thanks Dennis L.:ugh
I had a similar problem. My interior lights would flicker when I hit a bump in the road and eventually they would stay on. It turned out to be bad courtesy light switches in the door. They are located near the rear of the door opening about mid way down. You have to remove the door panel to change them out. Good luck.The background lights do not come on in any position-tried to find a fuse that is for that area-does anyone know where it is ? Thanks Dennis L.:ugh
