Twice in the past month the instrument lights on my '02 Z06 would not come on when I turned on the headlights. Both times it was twilight and I did notice the instrument lights came on as I opened the driver's door. Put the key in and the lights go off. Turn on the head lights and no intrument lights. I checked the dimmer and it was turned fully clockwise (brightest setting). Then tried turning the dimmer fully counterclockwise then back clockwise. Still no lights.
Finally used the main switch on the turn signal stalk to turn the headlights on and off. After 4 tries the instrument lights came on. This was a month ago and then the entire scenario repeated itself again last night. Tried to get the problem to repeat, but once the lights finally came on, they continued to come during further testing. I use the car infrequently; total mileage is 6800.
I know that this problem will not go away. So has anybody else experienced the same? Where should I be looking to solve this problem?
Thanks,
Mike
Thanks,
Mike
