chevyaddict
I am pretty sure the answer is no, however, I have what seems to be fluid marks that have spewed out in a splatter pattern right from the a/c compressor clutch. And, when the a/c is running there is this horrible burnt smell; everything is fine when the a/c is off. I thought it may be the clutch freezing up and making the belt melt but the belt is fine, and the spatter pattern is right where the a/c is. So, is there actual fluid in the clutch itself (1990) and then if so there must be a seal that can go, yes? :confused
