- Thread starter
- #21
chevyaddict
Dawn, I presume you have the Factory Service Manuals for your car. Your a/c won't work if the freon gets low enough that the internal gas pressure goes below about 30 psi (engine off and cool). Because there's probably still internal pressure in your system, you need special procedures and tools to work safely and protect the environment. If you've really lost all of your refrigerant, and the system has been empty for a year, you may also have internal corrosion that will cause many other problems. Your a/c shop will be able to evaluate whether this is a potential problem, and that may be why their price for the repair is so high! Read up on the procedures in the FSM so you can ask them the right questions, and have them explain their prices. Good luck on the repair. Hopefully, you've found an honest shop that won't take you for a ride!
By the way, the oil that's splattered on the underside of your hood from the leaky seal needs to be thoroughly cleaned off. It will eventually penetrate thru your fiberglass (really SMC) and cause blisters in your paint!
Yes, I knew that about the low pressure. Its a safety thing to ensure the system doesn't get damaged. I DIDN'T know about the bleedthrough though so I will go out there right now and clean that off! Thanks for the tip!!!
