abc
The fuel door will not stay shut/locked. It keeps opening up.
ad
I just hope the dealership has the part in stock as I'm already going in for a part they ordered for another problem where I was getting "Shift to Park" message on DIC. Turns out it needs new park/neutral switch that is on side of transmission. Hopefully these are two separate problems and not related to one another as they had to check ground when locating this problem.Jimailer said:Had the same problem had to beat on the side of the car:bang to get the plunger to stay out. Dealer:Silly will replace unit for free. Takes about an hour....
abc said:The fuel door will not stay shut/locked. It keeps opening up.ad
bt944 said:Same problem. Dealer removed pin/cable and lubed it. Works perfectly ever since
ErnieCorvetteC-6 said:Not here with 2 years of service.![]()
abc said:Turns out that it needs a new activator replace whole new cable. Before this I just had the Park/neutral switch which is attached to transmission replaced.
