- Thread starter
- #21
Ken
Gone but not forgotten
Left head, right head - no difference right?
If I swap the sensors around for the auxillary (pusher) fan from the left head (driver side), to the right head (passenger side) temperature switch location, will there be any adverse effects? I know that it should not make any difference, except that the right head will give a slightly higher temperature, correct? That's probably why the sensor was in that place to begin with. At any rate, I gotta do it because in my great wisdom to purchase mechanical gauges, I discovered that the capillary tubing is not quite long enough to reach the right head, so I gotta put it in the left. :duh
Now I'm trying to figure out where to mount my oil temperature gauge, also mechanical (oil pressure is mechanical too ).  The bungs in my Canton pan do not appear to be NPT threads and when I tried to use the original oil temperature sending location near the oil filter, I discovered then that I had no wrench to fit the thing!  My metric set is in my truck, and my truck is at the Ford dealer having the emissions system (EGR) serviced/repaired (I had codes remember?
).  The bungs in my Canton pan do not appear to be NPT threads and when I tried to use the original oil temperature sending location near the oil filter, I discovered then that I had no wrench to fit the thing!  My metric set is in my truck, and my truck is at the Ford dealer having the emissions system (EGR) serviced/repaired (I had codes remember?  )
I'm beginning to doubt that I'll ever have this thing on the road again.
_ken
_ken
 :J
  :J
 :cry
  :cry
