Wouldn't they exacerbate the arcing? Aluminum is a pretty decent conductor...
[RICHR]
[RICHR]
I still can't remember why we made the change, and I went from my initial choice of the Victor 23° Heads for roller cams, which areWhalePirot said:Next time, it'll be angle plug heads!
and went with the Performer E-Tec 200 Heads, which have:... ideal for racers looking for an affordable head that makes maximum power, the Victor Jr. 23° heads are designed for competition and ultra high-performance street small-blocks and accept standard valvetrain hardware. They have a 530-580 hp potential, out-of-the-box, for a cost effective, race-winning set-up. Combustion chamber sizes include 70cc or the new 64cc version that is ideal for entry level racers or high-end street. The 64cc combustion chamber yields around 10.2:1 compression in a zero-deck flat-top 350-inch engine, and about 12.5:1 when used with a 12cc domed piston. Both versions of the Victor Jr. 23° head feature high-flow 215cc intake ports with CNC port-matched entries, .300" raised exhaust ports, hardened, ductile iron valve seats and phosphor bronze guides. A 9/16" thick deck surface provides superior gasket retention. Match with an Edelbrock Super Victor #2925 manifold for maximum power.
Will must have wanted the smaller intake port size for increased velocity, because everything else except for the plug angles is the same. The Victor Jr.'s are also cheaper.... 200cc rectangular intake ports and 78cc exhaust ports. They outflow the “fast burn” aluminum heads by 10% on the intake and 17% on the exhaust , making power up to 6500 rpm. 64cc combustion chambers produce approximately 10.2:1 compression when used with flat-top pistons in 350-inch engines. E-Tec 200 heads come with 2.02" intake and 1.60" exhaust valves.
the later style or "Vortec" Heads have a different shape combustion chamber sort of heart shaped as opposed to the old style chevy or the D shaped in smog heads, although they were developed to meat stricter emission standards they also make more power which makes sense if you burn your fuel more efficently you will get more power.Ken said:I still can't remember why we made the change, and I went from my initial choice of the Victor 23° Heads for roller cams, which areand went with the Performer E-Tec 200 Heads, which have:
The E-Tec heads have straight plugs while the Victor Jr.'s have angled plugs.
I also had to modify the Mini-Ram to accomodate the Vortec-style cylinder heads. :eyerole
How much of an air gap do you have between the tube and your spark plug Mike? How much room does the Bakelite boot need? ...And what about those "snowmobile plug terminations." :confusedWhalePirot said:... I am going with Bakelite 'boots' from a local hot VW shop
Someone was on a power trip this morning, and mustn't have liked my Corvette's power intimidating his. So I laid down a couple of more sets (twice) as I pulled out of the lot. :LMe: "C'mon now, you know I did it."
Him: "Leave the lot." Turns and starts walking away.
Me: "Are you serious? No harm done."
Him: "You have to leave the lot, now." Starts walking away again.
Me: "Okay. What's your name?"
Him: "John So-and-so, service manager of Harbor Chevrolet."
Me: "Okay John. Have a nice day." :eyerole
