Keeping you all up to date with this week's problems....
#1: The Scoggins-Dickey clutch pivot support for the 502 does not fit when using a Lakewood scattershield.
The scattershield and block plate are wider than the stock aluminum bellhousing. How to fix it? Out comes the dremel to remove about a 3/16" of metal from the scattershield and block plate along a 4" - 5" plane where the right edge (in this photo) of the support approaches the scattershield. :eyerole Otherwise, I can't get the bolts through the support into the scattershield. The bolt holes are not visible in this photo.
#2: The DeWitt's SP022 — Aluminum Radiator & dual Spal Fans does not fit in my '67 in combination with the Vette Brakes Performance Plus suspension - in particular, with the new upper A-Arms.
A 1.5" length (about 1/2" deep) of the plastic fan surround on the driver's side must be cut away (at roughly the 9:30 position in this photo) to clear the forward area of the A-Arm and large washer. Likely, this is not DeWitt's fault as the rad/fan combo may work fine with the stock '67 suspension. Since I no longer have the stock suspension, I can't say for sure. Also, it does appear that getting the upper rad hose on to the new rad may prove difficult as the upper rad support seems to be very close to the area where the hose will want to be. Since I don't have the hose yet, we'll have to wait to see.
#3: My old Hooker headers won't bolt on to the 502 aluminum heads. No real surprise here as others have run into this problem. Removing a small amount of metal from the lower header flange area may solve the problem - the four lower head bolts are in the way. Until I see the old headers bolted on properly, I'm not ordering new ones.
The battle continues....... :Silly
