F
Fishman
I'm with Barry... chrome would look awesome.
I Vote For White....White would look nice against the black Valve covers and the red of the car. The Black color would be lost in the motor compartment.... and Chrome........well every body does crome...BarryK said:I vote for chrome. I think it would offset against the red of the car and especially against the black valve covers great and look awesome
Good advice, John. I just spoke to Holley (Hooker) Tech Support and even their new side-mounts #2222HKR do not allow for the change to the ZZ-502 heads.JohnZ said:Buy plain ones (that fit), and after making whatever modifications are necessary to fit them properly, send them to Jet-Hot for ceramic coating; you don't want to buy a set that's already coated and then find out they need modifications. Been there, done that.![]()
Here's how the pivot support would look installed.67HEAVEN said:#1: The Scoggins-Dickey clutch pivot support for the 502 does not fit when using a Lakewood scattershield.
The scattershield and block plate are wider than the stock aluminum bellhousing. How to fix it? Out comes the dremel to remove about a 3/16" of metal from the scattershield and block plate along a 4" - 5" plane where the right edge (in this photo) of the support approaches the scattershield. :eyerole Otherwise, I can't get the bolts through the support into the scattershield. The bolt holes are not visible in this photo.
Actually, 1Bad69 clued me in to a place here in Ontario that does ceramic coating. Finding out that even new Hookers must be modified in the lower flange area to fit my ZZ-502 means I won't be ordering chrome.Fishman said:I have the ceramic coated Hookers and would highly suggest them to anyone... you can even clean them with a dirty rag. That just was not one of 67's original choices whan the thread wa started.![]()
I have seen lots of folks with chrome and no problems. Maybe the expensive ones are better than the cheaper ones?![]()
It would be hard to get a good pic now that they are installed, but I would call it a 'shiny/flat silver'... kinda hard to describe. Nice color, not as shiny as chrome, but not dull either. My engine compartment is mainly black... black... black and some chrome. The color I have goes well with both the black and chrome in the compartment. At least I have been told it looks good. :L67HEAVEN said:Fishman,
What colour are yours? Got any photos?
Len,1970 Stingray said:I ran into clearance issues with GMPP aluminum head bolts too. ARP make a shorter lower head bolt/washer. It's a 12 point. Just switched my lower's out. The Stock bolts wouldn't work with Hooker Super Comps or stock manifolds. Should work with your heads and will save some grinding time.![]()
ad
