M
Mart
OK, Correct me if I'm way off base here, but this whole frame flex deal has me :ugh
So here goes, The whole vehicle sits on four points (the wheels), If I move those four points towards the center a foot or so the should be less room for flex, if I move them out towards the front and rear then the frame will flex more.
So when cornering the car must go through more flex than when it sits static on a lift or jackstands due to the other forces applied, not just the down force applied from the weight of the vehicle which is distributed accross four points.
In conclusion just how is having the top up or unlatched on your vert going to be affected, do you not corner agressivly with the top up?
And where the jackstands are placed on the front end is right below the bottom of the winshield and the hood, therfore there is no flex from there forward that would cause the hood to bind.
I don't get it....
Somebody splain this to me.. :W
Mart
I don't get it....
Mart
