i think i have a problem with my oil return holes....when i go out on the freeway for more than 30 mins i start seeing smoke....then i stop and look under it...its raining oil!...looks like its hitting the exhaust and smoking...not coming from the exhaust itself...and i cant really see where its flowing from....i thought it was a rear main seal , but i can drive it all over town and loose only a spot or 2 on the cardboard i keep under it....my question is , could it blow oil out of the valve cover gasket ? i was thinking it would blow into the cylinder but im thinking its coming out from the valve cover...the rear end of it , making it hard to see where its coming from....it only does this when i run at freeway speeds for more than a few mins.......im looking for opinions before i pull the entire motor and start doing something i may not need to....i am gonna pull the heads and have the valves done and the edelbrock manifold bead blasted this off season......so if its the returns , what is the best way to clean them other than a coat hanger?
