corvette1976
I will be away for 6 months with no computer access so no sales after the 28th of January. Thanks
These parts are mainly off two 1975 corvette parts cars but there is a shelf of 1979 vette parts in there too. It is hard to list everything so if you see it in the picture and there isn’t a price listed just make an offer. Will consider trades for shop tools.
Please note: ALL 68 Parts SEEN IN THE PICTURES ARE NOT FOR SALE. For example the front clip, the chassis behind it, and the shelf or 68 parts behind it.
The parts are located in Rock Hill, SC about 20 minutes south of Charlotte. Let me know if anyone has any questions or would like any other pictures.
1975 Parts’ list:
Door panel (pass.) (very worn) $10
Rear window - $50
T-top chrome trim “T” - $30
T-top chrome trim ( the ends of the “T”) $15 each
Steering box - $60
Bake booster - $50
Skid Lower trim- $30
Map pocket panel- $60
Master cylinder- $20
Windshield - $110
Automatic shifter- $20
Kick panel -$5 each
Door sill plate- $25 both
Distributor - $40
Center ac/heat vent - $35
Parking brake cable (good shape) - $20
Seat belt guides (metal rode on the floor pan) $10 both ---- one pair sold - one remaining pair for sale ----
Sun visor (one has the metal part broken on the inside) $25 pair
Rear view mirror $30
Differential heat shield $10
Parking brake $30
Radiator over flow tank $20
Windshield washer fluid container with neck $15
Hood support $30
350 Heads (more than a $100 worth of work on them) $110 ---- Sold ----
350 Block (bored 30 over) $230 ------------Sold -----------
350 Crank shaft $50 ------------- Sold ------------
Engine bay heater box with everything attached $80
Under the steering column cover $25
Shifter console $95
Shifter console housing $50
Brake pedal and mechanism $50
Door hinge $10 each
Steering column mount $40
Differential cross member $50
Front urethane bumper $125
Front bumper support rear bar $50
Front bumper support front bar with honey comb $75
In front of the firewall/ floor pan heat shields $15 each
Under the car exhaust pipe heat shield $40
Interior heater box $50 original heater core or $65 with new heater core
Half shaft $70 both
Spindle assembly $55 each
Coil springs $40 both
Leaf spring mount plate $10
Drive shaft $50
Upper control arms $60 both
Lower control arms $130 both
Trailing arms $175 each
Leaf spring $50
Front sway bar $40
Front hub and rotor $50 each
Seat belt floor pan cover $10 each ---- both sold ----
Upper dash (damage) $95
1979 Parts’ List
Rear bumper support painted $140
Passenger door shell $130
Sway bar with new bushings $50
Restored gas tank (no sending unite and might have a cracked blatter) $60
Hood support $35
Hood hinge $20 both
Auto shifter $25
Shifter console (damaged) $90
Mirror (cracked) $15
Sun visor $30 both ----------- sold --------------
Leaf spring mount plate painted $15
Trans dip stick $5
Shelf 1 and 2 (1975)
Shelf 1 and 2 pictures by corvette1976 - Photobucket
Shelf 3 (1975)
shelf 3 pictures by corvette1976 - Photobucket
Shelf 4 (1975)
shelf 4 pictures by corvette1976 - Photobucket
Shelf 5 (1975)
Shelf 5 pictures by corvette1976 - Photobucket
Shelf 6 (1979)
shelf 6 pictures by corvette1976 - Photobucket
Bigger Parts (1975 and 1979)
Bigger Parts pictures by corvette1976 - Photobucket
1979 Rear bumper $120
1979 Rear clip $235 Local pickup but can ship the fenders
Fiberglass Rear Clip ...... $295 - Corvette Forum
1975 corvette front suspension parts, sand blasted and painted. Sold as a pair. Upper control arms - $80. Lower control arms - $160. Coil Springs - $50.
Front spindles pictures by corvette1976 - Photobucket
1975 corvette seats $375 pair
1975 Corvette Seats - Corvette Forum
1975 Parts’ list:
Rear window - $50
Steering box - $60
Bake booster - $50
Windshield - $110
Kick panel -$5 each
Distributor - $40
Parking brake $30
Hood support $30
Shifter console $95
Door hinge $10 each
Half shaft $70 both
Drive shaft $50
Leaf spring $50
Front sway bar $40
1979 Parts’ List
Hood support $35
Hood hinge $20 both
Auto shifter $25
Trans dip stick $5
![DSC03898.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Shelf 1 and 2/DSC03898.jpg)
![DSC03900.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Shelf 1 and 2/DSC03900.jpg)
![DSC03901.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Shelf 1 and 2/DSC03901.jpg)
![DSC03909.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Shelf 1 and 2/DSC03909.jpg)
Shelf 3 (1975)
![DSC03928.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/shelf 3/DSC03928.jpg)
Shelf 4 (1975)
![DSC03965.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/shelf 4/DSC03965.jpg)
Shelf 5 (1975)
![DSC04008.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Shelf 5/DSC04008.jpg)
Shelf 6 (1979)
![DSC04050.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/1979 corvette parts car/shelf 6/DSC04050.jpg)
![DSC04051.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/1979 corvette parts car/shelf 6/DSC04051.jpg)
![DSC03985.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Bigger Parts/DSC03985.jpg)
![DSC03986.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Bigger Parts/DSC03986.jpg)
![DSC04045.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Bigger Parts/DSC04045.jpg)
![DSC04000.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Bigger Parts/DSC04000.jpg)
![P1010001.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/1975 corvette - blue/Trailing arms/P1010001.jpg)
![DSC02133.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/1975 corvette - blue/front bumper support/DSC02133.jpg)
![DSC03605-1.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/1979 corvette parts car/1979 body - current/DSC03605-1.jpg)
![P1010256.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Front spindles/P1010256.jpg)
![P1010196.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/Front spindles/P1010196.jpg)
![DSC03691.jpg](http://i279.photobucket.com/albums/kk136/corvette1976/75 corvette/seats/DSC03691.jpg)
