USNA1969
No. 1 cylinder has a compression of 130, the no. 3 cylinder has 135 and the rest are between 149 and 151. The valves are not bent or burned and the head gasket is intact. The cylinder walls and pistions appear to be ok.
Before I pull the pistons, is there anything else besides cracked or broken rings that would cause low compression?
