Ruby Fan
I have a '96 with a LTPWS(low tire pressure sys). After driving the required time for it to indicate if you have a problem, it lites up on the dash. If you re-start the car after a normal period, it's not there, until the required period again. I have a code scanner, and when I hooked it up, there were NO CODES found. Does anyone have a clue about this system? I think there is a way to make the indicator lite go off, but then you wouldn't have any use of this system. BTW all tires are up to proper pressure. A bad wheel sensor??? But if it doesn't store the code how can I find which one? Thanks
