O
omega1940
My 88 blew a head gasket. Since everything is coming off the top, I went to a local company (Exotic Muscle-Tempe, AZ) and ordered some equipment.
I am getting an Accell Super Ram Intake ($445.95) Accell Long-Tube Runners (359.95) a ported plenum, 24 lb. injectors (don't know the brand)at $295.95 and Crane Gold (Roller) Rocker arms at $335.95.
I have looked in C-4 Mods and saw one comment about not using Accell LT Runners because they are cast and don't work as well as extruded runners. Is the difference significant? Exotic Muscle is going to (I hope this is right) make sure the runners are properly ported to match the plenum???
I have a 52mm throttle body, adj. fuel pressure, K&N, Flowmasters, "Vortex" plate (behind the throttle body)
I also wonder if I need an MSD 6AL ignitiion set-up with this new set-up or stock will work.
I should have done some checking around, but when my mechanic said the heads had to come off (first time at 144,000 miles) I thought this was the time to move up.
Thanks,
Mike
Thanks,
Mike
