The73vetteman
My M20 leaks oil from the plate on the left where the shaft enters the case. Not a problem when it's low on oil, but when I fill it I then find oil all over the garage floor...
I've seen somewhere a kit to replace the seals around this shaft, but my question is, how big a job is this? Can I do it with the trans in the car or do I need to remove it?
BTW, one reason for the leak is that one of the securing bolts has been sheared off (Bubba had much fun with my car!) so I need to remove the threaded section from its mating hole. Any of you mechanics out there think I can do this without dropping the whole box?
