69MyWay
Okay guys, my jury is still out on this one. I am having Major problems, and I AM NOT HAPPY at the moment.
First of all, I realize that non of these aftermarket kinds of things will always fit right the first time. This long leg design is not preferred for vettes, but works for me for several reasons.
1. I get to use a standard style pwr steering pump with built in resevior (avoids having to mount a resevior on the inner fender).
2. Allows for use with taller valve covers
3. Actually cost less than the single serp belt short leg design.
Why I am unhappy.
1. Kit failed to come with the correct bolts (too short, wrong threads, some missing)-March is rushing me the correct ones.
2. I had to pound the living *&@#! out of the front cross member to clear the extra length of the crank pulley then sand, prime, and repaint the frame (glad I did not have it powder coated after all).
3. Either my balancer is not all the way on, or there is a serious pulley match problem between the water pump and crank. The inner crank pulley hits the back side of the water pump pulley.
4. They sent me belts way too small that won't allow me to set up the accessories on even the minimum adjustment mount.
I hope to get some of this straight today, and or pack the whole thing up and send it back.
You would think that for $1,400 this stuff would almost mount itself.
Why I am unhappy.
