Paul G
What is the difference between the ML9 and MN6 manual transmissions?
Don't know if this helps, but my build sheet has the ML9 next to 6SPD MAN TRAN. Mine is a '93 without the Z51. Goodluck.Ken said:Seeing as how this is in the C4 forum, I assume you mean a transmission option code for that generation, correct?
I can't however, find a reference to ML9 anywhere. If it's equipped with the Z-51 package, that may have something to do with it. My build sheet for instance, lists a MK2 along with the MM4 code for a four-speed manual transmission. I know we've discussed this before, but I cannot remember the answers now.
