G
ghfun
After some really great help here I still have the problem. I have visually checked the controler (in dash) and have no fault codes for either the controler or the Programmer which distributes the vacume to the various vents for positioning.
Everywhere under the hood I can find to check for vacuume it seems fine.
I can not seem to locate to trace the vacume hose from the engine compartment through the firewall to the programmer. I tried to remove the programmer box last evening to remove the screw holding the vacume lines on it but cant get any slack so that did not work.
I am lost at this point and had another email from a friend here who is having the exact same problem. Any further thoughts?
Thank You!! Mark ghfun@aol.com
