80VetteL82
Alright Im down to choosing between two motors. I can get one wholesale, but Im leaning towards the one that I cant get wholesale. Its made by Blueprint engines. Heres the stats on it:
<P>
Block:
* 4-bolt main block
* Passenger side dipstick
* Square and parallel decked
* Align-honed main bearing bore
* Cylinders honed on computer-controlled machine to within .0002 straightness and roundness
* Cylinders are sonic tested for thickness
Rotating assembly:
* New SCAT cast crankshaft
* Chevy heavy beam rods
* Keith Black hypereutectic pistons
* Hastings moly rings
* Balanced rotating assembly
* Melling high-volume oil pump
* Flat tappet hydraulic lifter camshaft
* Heavy-duty double roller timing set
Cylinder heads:
* New "Vortec" cast iron cylinder heads
* 1.25 in. diameter valve springs
* Hardened retainers and springs
* 2.02 swirl-polished intake valves
* 1.60 swirl-polished exhaust valves
* Hardened pushrods
* Professional Products dual-plane satin finish intake manifold
* Edelbrock 750 cfm carburetor
* MSD distributor and coil
* Professional Products balancer
* Edelbrock 110 gph fuel pump
* Edelbrock satin water pump
* MSD plug wires
* ACDelco spark plugs
* 9.5 to 1 compression
* Chrome steel valve covers
* Brass freeze plugs
* Dyno-tested--and shipped with results
<P>
So, my question is if I buy this turn-key engine what else will I need for the installation as far as parts go. What Ive thought of is headers, motor mounts, pulleys, probably all new vacuum lines....anything else? Also, do you think the stock cooling system on a 1980 L82 will cool this 383 stroker? My other question is what do you guys think of this motor? Anybody ever heard of Blueprint, or have any experience with them?
Thanks ahead of time for any advice,
80vetteL82:W
<P>
Block:
* 4-bolt main block
Rotating assembly:
Cylinder heads:
* Hardened pushrods
* MSD plug wires
<P>
80vetteL82:W
