security reasons
True, too. One way to defeat the alarm system is to puncha hole in the batery, through the gill. After the acid drains, no power feeds the alarm system. Some use blocker sheets; others move the battery.
No change is free, however. I am still tracing my hard-start-when-hot issue, and am not sure if this (2nd) Optima is also bad, or if I am not getting a proper charge, despite the heavy cables, to the battery. My DVOM shows almost 1 vdc drop from battery to atlernator, which is high, if true. The charging voltage at the battery reads +1vdc relative to the dash.
