my crisis cure
As luck would have it,. the one day I want to come home from work, and go (very quickly) burn some fuel on the parkway. I have my first problem with my 2001 C5. Quick details are as follows. Up till now , I've had no, absolutely none, problems starting until today. I get in, insert the key, wait a second, (as I always do to watch the gauges cycle through). turn to start, and CLICK. ..:confused. WTH????.... Gauges drop out, interior lights dim, brighten back, relays click and whir, and I sit stunned for just a moment. Ok, , just a loose connection on the battery, Get out, pull the hood, check the cables, seem okay, no corrosion, the terminals seem tight. Torqued em just a little, just in case. Underhood light's nice and bright. I hit the lock/unlock buttons on the keyfob, and again lights drop out. Pulled out the battery load tester, disconnected the battery. load tested it. Static voltage at 13+_. holds at 11.5 at full load for 15 seconds. Reconnected battery after about 5 mins and try it again. Same results Past experience would dictate a loose connection somewheres, but nothing that I can see from under the hood. As I certainly know better than to just start yanking on wires,. I hope someone can possibly give me some direction in which to proceed. Many thanks for the help. Chris
