J
jedi
Here is a good mystery for you Corvette masters. I have another leaking seal, this time it is coming from somewhere in the transmission. Every morning when I go out to the garage I find a small puddle in the middle of my floor. This time it's red, so therefore it must be coming from the transmission. I took the car to a local jiffy lube and had the transmission pan gasket replaced. Then I took the car a few week later to Amoco to have the transmission checked. It seems to slip a bit in 2nd or third (Was doing it before Jiffy) but I suspected the flywheel was slipping on the oil from the old oil leak. Amoco had it over night and they found "A" source of a leak. The speedometer (or something like that) had a seal that was leaking. They replaced that but did not find anything else wrong with the transmission. No codes no nothing, just the occasional slip which they could not reproduce. The slip itself is a little weird no change in rpm just a brief loss of power. Amoco also noticed that the bolts on the transmission pan were not tight and suggested I take it back to Jiffy. The leak continues, Jiffy could not find it, (then even let me down under the car to look) Amoco could not find it. Where could this be coming from? Any suggestions would be very helpful.
Jedi
Jedi
ad
, seems my intake valve failed again. That is the 4th time that it would have to be replaced. Pohanka had to do it 3 times before they fixed it 6 months ago, and it failed again
, but there is no way in h#ll I will go back to them.
