76okievette
Great post, I wish I had your problems, 55 deg air would be great! I never got my 76 down below 70. I converted to R134 and install a part called a VIR eliminator (dryer) but it never worked right, may never of had a correct charge not sure, now I have leak in the tubing right behing the compressor. I am considering just going with a system from Hot Rod Air http://www.hotrodair.com/index.cfm From Hot Rod Air
The systems require no major modifications to the car and are comprised of all new (not rebuilt) components. The kits include the evaporator, compressor, compressor bracket, precrimped hose kit with drier, condenser and safety switch. its 1200 bucks.
Has anyone ever done that or know any thing about it? It includes a total system, compresser, evaporator, consener, ducting, etc.
What do you think is it necessary to replace everything or should I just try and make the OEM system work? Thanks
See attachments below for POA adjusting procedure!!
