HallenTi
I have a 1990 coupe, 148,000 miles. I live in the Seattle-area. I figure the car is in reasonable shape, so is probably worth $8,000-$9,000. I "like" the car, but am not attached to it, and was comtmplating selling it for a C5 at some point in the near future.
In doing the intake manifold leak fix I dropped a nut into the engine but didn't know it at the time. Ran it, heard the noise, shut it down and then had it towed to a local shop and they had their engine guy come look at it. I have seen it as well.
Head is a little beat but fixable (no replacement needed according to a local aluminum head repair man). Piston (#3) is beat up and needs replacement. Engine guy says the lower portion of the cylinder is "belled-out" 0.005" due to the way the nut sat on the piston for the 1 minute total running time it had. I need realistic opinions on the following ideas...
The engine guy can maybe "patch" it by honing some from the bad cylinder, but says it will probably use oil... not sure how much oil, but will use some he claims.
"Patch job" estimate is about $2,500. "Best way" (bore all cylinders out 0.030 over, new pistons, rings, etc. etc.) necessitating removal of the engine is $5,000-$6,000.
One option I haven't checked into is a sleeve, but not sure if that can be done, and if it could possibly be done in the car to avoid the 20+ hours shop rate for the engine remove/replace.
I can't see spending between $5-6,000 with the car valued as it is. I could maybe go for the $2,500 patch, but I believe there would be no guarantee on the work given it is a patch job he says.
Checked into a used 1989 engine (only one I can find even in neighboring states), and it is $2,500 with a 90 day warranty, and no idea of the mileage (has 170lbs compression in all they said).
Checked into a Chevrolet crate engine, but none are available back further than 1992.
What do you think I should do? If I repair it either way, I would feel that I needed to keep the car a while to get some of the money out of the expensive repair. In review, the options are:
A). Patch job at about $2,500 - no guarantee
B). Complete rebuild at about $5-6,000 - 90 day guarantee I believe
C). Possible sleeve te bad cylinder (somewhere between A and B price-wise I expect)
D). Sell the car for parts
