Seriously now...
Here is one a little closer so you can see the connectors.
Closer still.
Now that I was shooting pictures of that stuff again, we may as wll kill two birds with one stone here, or as the case may be, two questions with one thread.
When I had the interior apart last year, I came across this and wondered what it was and where it goes (mounts), but I have always forgotten to ask. Now I'm asking. The books have no clear reference to this item or the next one. The item was warm as I was working in there tonight, so maybe it has to do with the interior time-out on the lights?? :confused
This one has me stumped too. The bracket you see taped to it was made to fit exactly as you see it, but there is nothing with which to attach the bracket to the unit and then I don't know where the bracket mounts up under the dash.
And if this is the VATS module, what is that thing mounted to the dash behind the "breadbox"?? :confused :confused
This is what happens when some idiot gets to it before you do. I mean, if I was the first in there since it left the factory, I could probably figure out where these things were mounted. But because someone else got in there to change the dash pad to a simulated wood thing (which I removed and replaced with the original pad), The parts were already loose and just hanging there.
_ken
