E
ediconu
new: crazy traffic concern
Hey guys, I've been reading around this site for a while, since I've started my search for a nice C4. I've found the site extremely helpful in almost every area. I've found a few 1995 LT1s in my area, yet the better of the 2 has the stock thermostat and the SLIGHTLY worse one has a 180 degree therm. (By better, I mean less miles and a new clutch)
THIS IS THE CONCERN:
I've read countless threads on this and I don't want to start another, "that's useless," sort of baseless argument. I know that excess heat will wear an engine and make it die earlier. I know that since I drive into washington DC every day, my car's going to be sitting in traffic completely stopped for extended periods of time. I know I don't want it to live at 240 degrees.
Based on this, how do I go about getting a cooler therm and computer chip to match and other things like making the fans come on at 180 instead. I'm not looking to go all out and get a new radiator (yet), I'd just like to alleviate the symptom because on the ride, the time that I drive under 35 MPH isn't more than a couple of minutes at a time.
If anyone feels strongly that I should not change these things, I don't mind if you voice yourself, but please leave a whole ton of references in your wake so that I can follow links to credible sources that back you up. That way I can filter through the... how do you say.... BS.
On a side note, I'd like to be able to plug my laptop into my car's computer and look at all the random stats that the ECM records so I'd like to know exactly what TYPE of thing I need for that. I've looked around and it appears that most of the "Chip reprogrammer" things are like calculators that you hit numbers and it changes things, I want a little more than that.
I didn't mean to sound like a.... sorry 'bout that.
Thanks in advance for the help
