New to carbs
Bolisk
Crystal Lake IL
1972 LS5 Convertible PS, PB, A/C
So, I've got a spare quadrajet that I'm going to rebuild so that I can learn how they work. . .and practice how to rebuilt the one on my vette.
I have a few books, and I'm reading through them.
One of the things that i have not yet come accross is how to identify the "size" of existing parts. . .like Jets, Needles. . .etc.
Is there a simply way?
For example, I know that my engine is running lean right now (temps have averaged 50 degress recently). Can this be due to cool temps? Or would this lean problem be a year round? If it's a year round, then I assume that I need to increase the jet sizes. . .but I have no idea what I have currently. Hence my question. Not sure if I need to change the needles as well.
Second to last, I read in the carb book that I should change the accellerator pump push rod to the other hole when the weather is cold. . .to prevent quadra boging. . .which I am seeing. Does anyone do that?
Lastly, has anyone used quadrajet parts from Fliffs High Performace Quadrajets? If so can you share your experiences?
Peer81
Netherlands
'81 Black
I think all the info you'll need are in Doug's and Cliff's books. I know Cliff's book shows all the jet and needle sizes ones made. You can check it with a dail indicator or look for the numbers on the needles (jets I don't know).
I ordered parts from Cliff a number of times. Asked different question and always got a good answer. So for Q-jet parts I will always go to Cliff.
Greetings Peter
6880 Mike
The Bluegrass State
1968 convertible; 1980 L-82
...One of the things that i have not yet come accross is how to identify the "size" of existing parts. . .like Jets, Needles. . .etc...
They're marked.
Worth the cost of a copy:
:thumb
