02silvet
New member
I inherited a 2000 conv. c5 5.7l. Roughly maintained cosmetically and probably most fluids except the oil.
Seems to run fine and doesn't appear to have any leaks. Has a squeak in the belt, I think, with a couple dash lights on. ABS and the traction control.
Do the Windows index on this model cause they are outside the top in the upper rear corner?
I'll have to try and reset the rear window. The battery was replaced at a discount warehouse early this year.
The tract control light is on but no codes on my torque pro app about it and pushing the console button does nothing.
Had a catylist code and I've cleared it to see if it returns. This thing hasn't been driven at all for a year plus, maybe just cranked up.
The oil looks great on the stick but the DIC says oil life is up. Can I set this up for the reminder at 8k for synthetics?
The tires are a Michelin Pilot Sport AS, 17" front and 18" rear, and say 51 PSI. The door tag says 30 PSI. What should it be?
I think the electronic tire pressure sensors are not working or disconnected cause the DIC is reading something about the TPM.
What gauges do I need to set up on Torque app and where can I get the readings needed for pressures and temps.
Any and all help is greatly appreciated.
Sounds like you have a good project there. Another thing on the belt squeak is the harmonic balancer. It seems to me that it could be a cause. Might want to take a look at it and see if it runs smoothly and straight. If it wobbles, then it needs to be replaced.
