N
NORMAS VETTE
First Of All Thanks For The Info The Last Time Around. You Guys Are Great. Haven't Had Any More Problems. I Do Have Another Question For You Which I Hope You Can Help Me With. When I Bought The Car The Temp Oil Gauge Was Not Reading The Temp. The Needle Just Stayed On 0. I Changed The Sensor Which Was Practcally Under The Windshield(very Hard To Get To) But Put In A New One. The Gauge Started To Read The Temp And Lasted For About A Day. We Thought The Sensor Was Defective Which Is What The Chevy Dealer Told Us. And Went Ahead And Bought A New Updated Sensor Supposedly Had Been Replaced For The Older Model. Before I Put The Sensor In I Had An Oil Change And Changed The Oil Filter. When I Put The New Sensor In, Everything Was Fine For About 24 Hours And Then The Needle Now Moves From Side To Side Whenever It Wants To. When You Turn On The Car It Tells You To" Service Engine Soon" And Dtc# C2120 Is The Only Thing Showing. And Also When You Accelerate Quickly It Gives You A Warning Low Oil Pressure And Then Gives You A Reading Of Oil Pressure Xxx. I Reset It And Its Fine For A While And Then Does It Again. Do You Have Any Idea About What's Going On Here???? I Would Really Appreciate Any Advice You Can Give Me......thank You Again.
Normas Vette
Normas Vette
