Over the hill
dougelam
Michigan
2002 Roadster
My Roadster hit 100k
Sent from my SM-N920P using Tapatalk
Only 900,000 more miles 'til you turn over the odometer...! ;)
Just getting broke in! :L
Trouble free??
Sent from my SM-G930P using Tapatalk
I would say yes, I did get a good deal on it with 50k in the clock because it had a bunch of pidly things going on. It was someone's daily driver that never washed it. It took a while to clear all them up. It is running just over 200 on the temp gage so I'll need a radiator and t-stat in the spring
Not to bad then. I'm almost at 50k now on my '03 ZO6 and so far all I've had is the brake module and air valve. Hoping for long life, it's my daily driver. Congrats on the 100k
Brake module?
I replaced it!
The one that I took off had a Hollander number on it just like my radio, IPC, radiator, condenser and who knows what else.
I did install C-6 shocks last year and WOW what a difference!
The driver's window up switch takes more pressure to activate than normal
I believe it's time for torque tube couplings also, was hoping for a 3:42 ratio rear end swap at the and time
Sent from my SM-T530NU using Tapatalk
So whats the problem with that,200-228 is normal under most driving conditions........:thumb
Yes but it is running hotter than last year.
Cleaned out the condenser and radiator fins and checked the lower air dam so far
Due to the supercharger; I'm running a 160F thermostat. The intercooler blocks air flow to the radiator. So far, the worst I've seen was a bit above 200 in over 100F in traffic.
