PCV valve on the Zs
Where is it and how do you get it out? Thx.
Pass Side in front of valve cover at throttle body!!! It's in a rubber hose,just pulls off!!:upthumbs
attachment.php
Thx guys--pulled the pvc out and it rattles freely--means in good shape right?
I've read some threads that say if it flows air one way its good. If it flows air both ways then it needs to be replaced..
Also have heard its a good thing to check the plastic tubes to make sure the hoses don't leak..
If they leak the car will run lean or so I've read.
