- Thread starter
- #41
B
Blue82
MoeJr mentioned the kickdown sleeve. If you go with the 3.73 gears, your RPMs will go through the roof when it kicks down from 4th gear at 50% throttle. The B&M sleeve will kick it down at about 75% throttle making the problem much worse. I modded my 700r according to a suggestion on the Crossfire forum and it will not kickdown ever from 4th gear unless I manually shift to third or I get my speed down below about 45 mph.
It's a simple mod and I talked to the guys at the local B&M shop about it and they aggree it is best for performance applications and it will not harm the transmission uless you are lugging it in 4th gear and then put a lot of torque to it expecting the car to take off. It will not kick down and will stress the xmission.
