69MyWay
Stommer said:Hi Everyone, How do you get the smiles to appear??? I'm not very good with this computer stuff yet.
Hang in there on the smilies. You have to get I think at least 15 posts before they are enabled for you.
You are fortunate because you have the LT-1 engine to start with. That means that your intake manifold is very friendly to performance upgrades.
Speed costs, so nickle and dime stuff won't do much for the seat of the pants feel. These things tend to run in $1K to $2K increments before you can REALLY feel the power change.
You need to do a little research (click on the specifications page here at CACC to start with) and try to determine what rear gear you have right now. You need to build around that and the transmission if you want to stay in a low budget. Otherwise, change the rear gear to a ratio that pushes the RPM higher on the engine, then, you will really feel the punch of more fuel pressure, better intake air flow, and any ignition upgrades you do. By putting a 3:73.1 gear in that car you can shave a second of the 1/4 mile time and maybe even that much off the 0-60 which is a significant improvment.
Oh, better take out stock in the major oil companies because fuel consumption will go up as well.
Good luck and let us know what you do!
ad ,
